Note: We recommend that security be enabled unless there is a compelling reason to disable it.
FME Server enables security by default. When security is enabled, the Web User Interface has log in and log out capabilities. Also, a Security tab appears on the Web User Interface to allow you to administer security.
To disable FME Server security, set the ENABLE_SECURITY option to false in the following configuration files:
